Windows don't roll down
Ok, i have been trying figure out why the rear windows just won't roll down 90% of the time sometimes they will but mostly they are stuck, I checked the motors they are good, the windows aren't jammed or anything, even checked and tried different switches. The wires are good did a test on those to, I remember hearign something about a controller or something that if it goes they no longer work but havent found much info on the subject. any suggestions out there?
1998 Land Rover Discovery (aka. The Green Devil) Ok a friend at Texas Rovers showed me this http://www.roverparts.com/Parts/AMR1282RK.cfm?bc=ab a few minutes ago, going to give it a shot tonight as I have those connectors and supplies already in my wiring kit. |
search for "rear window ecu " it may be repairable or there is a by-pass repair
noooooooo don't use that kit, it's a waste. do the search like Xceller says.
looked at the kit, seemed a bit overpriced to me, had to put this on hold as I having some serious brake problems I have to figure out. for some reason they work for about 15 miles then slowly bind up to the point i cant move the vehicle, the pedal gets brick hard to.
Start with a complete brake flush, all four wheels, takes about 2 quarts of DOT4 fluid. You won't like the color of what comes out....
Have bled them, like 5 times now, no air or dark fluid comes out, crystal clear clean fluid. I am reallly thinking it is that strange looking master cylinder, they swear it works for that vehicle but I am skeptical.
The shop put the thing on before I hada chance to say no. But here isa picture of it. http://ebay.alldiscountautoparts.com...s/10742944.jpg Had to really hunt for it not to many pics of it |
I had the exact same symptoms when I replaced my master cylinder with one from Rock Auto ... it'd go fine for a while, then the brakes would slowly clamp on all by themselves, pedal absolutely solid. And my replacement MC looked just like yours. I think the plunger on those is just a tad short, which slowly builds vacuum in the booster and slowly turns the brakes on.
Ended up springing for the genuine article, which solved all of the problems immediately. Didn't even need to bleed them again. |
Originally Posted by zappy
(Post 304217)
Had the same trouble with my rear windows,
This "Repair a Land Rover Discovery electric window ECU to make the rear windows open again" fixed it. |
| All times are GMT -5. The time now is 05:25 AM. |
