When getting back the black cover under the ventilation blower in the passenger footwel, I remarked a thick red wire connected in a grey connector with is plugged in a green box aside the blower motor. (All other wires in these connector are thin) The other end of this wire was not connected.
Other end of the thick red wire is not connected Better sight on the gray connector (here unplugged)
Is this OK ? Or have I cut by accident that wire by taking away and replacing the black cover ? What serves this green ECU for ? Behind the gray flat connector, is also plugged a smaller green connector with less wires.
Do someone knows where this wire normally must be connected to ?
Could this be the culprit for my interior lights not coming up anymore when opening doors ?
By chance has anyone had any success in extending that red wire to improve the range of the key fob?
I usually have to stand right next to truck to unlock.
Here's an idea. It's probably a 1/4 wavelength antenna. So, making it exactly twice as long could help, or 4 times as long. Other lengths could make it worse.
PierroDisco - for the courtesy light issue - check Fuse 6 on Satellite block 2. If that is still intact the courtesy lights are probably not coming on because one of the door sensors are not connecting and need to be replaced (one for each door + the far back door).
