00 disco possible engine concern
Old Sep 15, 2007 | 09:21 PM
ceomilord's Avatar
Default 00 disco possible engine concern
Hello everyone. My girl has been driving my 00 Disco (77k miles) for the last few months & I just drove it tonight & noticed a slight burning smell coming from the engine bay. (I recently did the full 60k inspection - wasnt sure if it was done by previous owner). Anyways, when I checked under the hood & there is a toothpaste looking goo that is over the drivers side of the engine. its underneath the air intake on the flat black section of the engine cover. it's also along the side above the spark plug wires. Obviously, I'm not an expert on my explanations here, but I'm trying to paint the best picture possible. Any ideas on where to start or what could be wrong? The car has been running fine, but I just want to take care of this issue b4 it gets worse. Thanks in advance guys.
Guillermo
Old Sep 15, 2007 | 09:25 PM
Default RE: 00 disco possible engine concern
Common problem, your t/body pre-heater is leaking coolant. Rover makes an up-dated version of the seals in a new kit.
Old Sep 15, 2007 | 09:47 PM
ceomilord's Avatar
Any idea where I can purchase this kit? Is the install difficult? Should i take it to the dealer? Thanks
Old Sep 16, 2007 | 07:43 AM
Dealer part only, and no it is not difficult if you are mechanical in nature. Also use only DexCool coolant.
Old Sep 16, 2007 | 04:02 PM
ceomilord's Avatar
Thanks Mike. I'm going to pick up the new seals & get the job done. I had already put in the BMW coolant for now, but will change over when i get all the other work done. I figured that its better to have some wrong coolant in there vs. none. Also, I'm going to updating the OME Steering stablilizer as well. Any particular brand to buy? thanks again & you guys rock!!
Old Sep 16, 2007 | 04:07 PM
Old Man Emu stabilizer as well as shocks if needed.
Call Tony to order the stabilizer at 650-365-4145 for about the best price on line.
DonRW2007
Oct 31, 2014 11:07 AM
llPANCHOll
May 16, 2009 09:46 PM
discoboy
Feb 7, 2009 04:58 PM
DeShawn
May 5, 2008 07:02 AM
jmrover
Oct 15, 2007 07:41 PM
