02 Disco will not start HELP!
![Frown](https://landroverforums.com/forum/images/smilies/udbMv2o.png)
I am unlocking with the key. The fob has never worked since I have had it. The alarm arms and disarms with the key in the drivers door just fine. The security light blinks.
Is this affected by weather temps at all? What voltage is your voltmeter reading at the starter terminal with the key on? I am gonna guess grounding problem since you were able to jump it.
Wiring goes:
+ Battery
50A fusible link (under bonnet)
Inside Fuse Box
Ignition Switch
10A fuse (Inside Fuse Box)
Starter Relay
BCU
Ground
Wiring goes:
+ Battery
Inside Fuse Box
Ignition Switch
Starter Relay
BCU
Ground
Sloan74. I checked all the grounds are good. Cleaned them while I was checking them. The ground signal to the stater motor relay is not present. That is supplied by the BCM. The BCM is not sending it out. What is cause this? I have jumped ground from the negative battery terminal and it starts and runs fine. Any suggestions I will try. Anyone?
I understand you checked all the grounds. At this point all I can say is that I have personal experience myself and vicariously through others with poor (not bad) grounds preventing the starter to pick up (even after I have cleaned them) (multiple times through the years...)
Anyway, one other thing I have seen is the key switch is bad and not making contact in the start position. You can probably do a continuity check on that if you look at a wiring diagram. (just make sure to disconnect the battery when you do a continuity check.)
If your key contacts are closing I would replace the battery ground cables before I assumed it was the BCM. They get old and brittle.
Just some suggestions.
