02 vs. 03
02 vs. 03
are there big differences between these two models, for someone like myself who will only be using the truck for around town and beach excursions, kayaking etc...no real off-roading...exterior and interior the same?? im just wondering if i should save some money and go for an 02 SD rather than an 03-04...advice? thanks
Stay away from the 03, period. They had a bad batch of engine that the only way to fix once the oil pump fails is replace the engine. So the question is 02 or 04. 04 all the way. It has the bigger engine, new style headlights and center differential lock. It's not worth saving money by sacrificing features you'll want later on.
on
If you are not needing the extra traction of an eariler D2 or a 04 then lean towards a 02. Many of the 03, although they have the 4.6 engine also had major engine failures because of the oil pump failing.
If you go for a 03 make sure it the vinn is not on Rovers list for potential engine issues.
If you find a vehicle, get back to us and leus know what you find and the price.
Disco mike-
in regards to the oil pump issue...i spoke with a LR Mechanic from the Boston dealership (whom I consider to be trustworthy) who said that if the oil pump is going to be an issue you will see it in the 1st 10-15k miles, the latest being 20k that he has ever seen it...any thoughts on this?...i see so many 03's with over 50k miles and wonder if it is saf eto snag one these...
Disco mike-
We have seen many oil pump failures on here and this was the range that they all went bad at, one or two almost 60,000 miles but that is very rare.
Save your money and get the '02.
Disco mike-
If you find a 03 that you're interested check the VIN against the bad engine VIN range. Keep in mind that is a generality. Some trucks in that range go forever with no problem while trucks outside the range die because of the oil pump. Get as much maintenance history as you can with any vehicle but that is especially important with a 03.
on
They can fail at any mileage so even if you may trust this guy, he is giving you bad information that can cost you down the road.
As a test, have him sign a contract with you stating that if the oil pump fails, he will replace your engine at no cost to you, then you'll see the real side of this issue pop up.
Even if I had this extra 10 grand sitting in the bank, I would not want to be living on pins and needles owning an 03 and wondering when it might go bad. You could be hundreds of miles from home and experience the failure. I just wouldn't want the stress of not being able to trust what I was driving. Every little sound would drive me up the wall. Spend a little extra and get an 04. Have piece of mind and get probably the best Disco ever made.
