03 disco cdl
Old 07-25-2019 | 03:48 PM
redwhitekat's Avatar
Default 03 disco cdl
Anything in the cdl wiring harness that would make disjo not crank ??? Mechanic replaced my transfer case with a cdl one. Now says it won’t crank
Old 07-25-2019 | 04:17 PM
Best4x4's Avatar
Is the PRND321 showing it’s actually in park. They might have removed it & messed with the alignment of it.
Old 07-25-2019 | 05:42 PM
I got it towed home found they disconnected the transmission cable from shifter and tranny and left it in neutral. That’s why it rolls Now I have to take the inside apart to try and hook up my tranny cable and my new cdl shifter
anyone know if it easier to hook up the tranny cable from underneath or when I take the consul out
Old 07-25-2019 | 05:56 PM
Llamasayswhat's Avatar
Check the ultragauge to be sure about the coolant temps
Old 07-25-2019 | 05:57 PM
Just joshing. You'll have to go from the top to attach the cable to the shifter end. The transmission attachment point is easy to access from the ground, especially if you have a lift on it
Old 07-25-2019 | 06:13 PM
Best4x4's Avatar
The cable end at the shifter normally isn’t removed from the assembly. It is usually just disconnected at the XYZ switch via a 13mm nut. Then from above the entire assembly lifts out. I’d hope they just disconnected it at the XYZ switch vs up top.
Old 07-25-2019 | 07:44 PM
Ok so got everything reconnected the dash does not recognize that it’s in park but shows if I put it in r n etc
Old 07-25-2019 | 07:58 PM
Best4x4's Avatar
Give it a bit of slack like 1-2mm and see if it shows P, or leave it disconnected & manually put it into P and then cycle the key & see if she’ll start.
When I installed the 04 CDL in my 02 I did a test drive & it wouldn’t start at the gas station. I quickly climbed under it, loosened the 13mm and gave it just 1-2mm and I was good to go.
Old 07-25-2019 | 08:11 PM
That’s it I was wondering why it was rolling and it was in drive but what they did was mess around with the cable going to xyz switch. I loosen the nut and moved shifter to park.
Now it starts and I can get the key out.
Anyways Thanks for the help
tomorrow is the cdl linkage install and reassemble
Old 07-25-2019 | 08:37 PM
Best4x4's Avatar
To properly adjust it manually place the Transmission in park, then have your shifter in Park. Pull it snug by hand and let it go back 1-2mm then tighten the 13mm nut and go from there. A small adjustment is usually all that is needed. I've worked on em in all sorts of conditions. Shifter in D but trans really in 3rd or worse. Park & manually set Park at the trans should work every time.
Quick Reply: 03 disco cdl
