03 HSE with vibration issues
I recently purchased a 03 HSE7 with 73k on it. I read the service history on it and it was a RAV, that had been in and out of different dealerships for mainly vibrations @ 45 to 70 MPH. The dealers changed out tires,front end parts, ace ecu modules ect...
I still bought it any way. I got a good price (6k under blue book) from Rover. When I was driving home I felt a weird vibration at 23 MPH and then again at 46 MPH. I brought it to The Rover Shop in Lake Villa IL. Glen and I took it for a test drive and he said lets look at the drive shaft. It seemed fine, but the drum at the back side of the T box was loose. He pulled it apart and found a loose screw inside the drum and some play in the connection from the rear drive shaft to the T box. He tightened up the screw and put it back together. I drove it home and it felt like a new truck. No Vibrations! Smooth as Glass! All the many dealers and could not find this problem for 6 years. I would again like to say thanks to Glenn and if anyone has any problems in the Chicago land area do your self a favor and call Glenn @ The Rover shop if you can't figure it out I'm sure he will.
Vic
Vic
We did check the drive shaft, it looked good both front and rear. I am going to be doing a tbox oil change just to se how the fluid is and if there are a lot of shavings in there. Jbegin , yeah I have a few Rovers, kinda sickness I guess but in all fairness my teen drives the 99 D2.
he better tell me first tho, i know from being here what to look for
Well U.P. you are right for the most part, if it was like you say if would not matter as the shaft nuts would fix tighten the drum and be OK. But if the screw was threaded out about 5 or 6 turns when the drive shaft nuts are tightened then the drum will be loose and the shaft will be tight but not seated flat onto the drum causeing the rear shaft to vibrate and the drum to be loose.
