19 years later, first rust
I'm a fanatic about checking for rust anywhere and keeping the chassis well coated.
The driver side front door plastic sill was broken, so I took it off and the seat bottom, to both repair the sill and clean the carpet, and found surface rust on a weld holding the seat to the floor!!!
19 years later, and find rust on the inside!! It's been completely stripped down to metal and etching primer used, going to cover with POR-15, then reassemble everything.
Brandon318 (12-23-2022)
