1996 Disoc 1 Diff Lock Question
www.discoweb.org, click the tech link, there is a CDL solenoid install link. Not sure how to tell if it is good or bad.
If you have not used the diff lock regularly the shifting rods under the truck will rust up and make it hard to shift.
If you let it go to long you will have to take everything apart and clean the rods.
Yours still move so you maybe able to spray penetrating oil on the rods and work the shifter slowly don't force it,,
good luck.
good luck.
ORIGINAL: Urban Panzer
I give up on this forum, cannot post more than a few lines....some one sort it ffs !!!
Agree with Landzu, give everything a good spray from underneath, then work it !!!, it will free off
