2" lift with SLS
2" lift with SLS
I have a 2004 DII SE7 with SLS and am wanting to gain a little clearance for some larger tires. Is there a kit out there somewhere that will safely lift a Disco with SLS yet still retain the rear air suspension. I have seen spacers for the rear advertised but what does one do about the front then. Do the springs need to be swaped out for larger ones or is there spacers available for the front as well? and if so what are the pros and cons of each option? I dont plan on doing any extreme off roading but the occasion trip through some mild to mediumIdaho back-country would be nice. Also, I dont plan on running 16 inch wheels as most people seem to suggest, I will be running the 18's hopefully with 265/65/18 AT's. Would 2" be enough for these tires? I am pretty sure it will, but thought I would ask before I look like a total idiot. Any help from someone who has lifted their Disco and retained the SLS would be appreciated. TIA
on
RE: 2" lift with SLS
Send me your tele number and I'll call you. I have a 99 D2 with SLS and ACE with a near 3" lift.
mikeljacobs@comcast.net
smokin
09-06-2013 01:19 AM
