2" rte
Old 02-05-2010 | 08:52 AM
dirk124's Avatar
3rd Gear
Default 2" rte
i am new to this. ive been lifting mostly jeeps my whole life. i cant seem to find information on what im planning to do... im getting new 2" rte springs. i need to know what else i would need. its mostly going to be for looks. and can i use the oem 18" wheels? and what is the biggest tire i can run? do brake lines need to be adjusted?
Old 02-05-2010 | 09:02 AM
gowest's Avatar
You will also want to look at getting replacement shocks as well. You can use the 18" rim and go up to 275 70 18 with a little front end rub (maybe). No need for any brake line extensions with 2" lift.
Old 02-05-2010 | 10:44 AM
You will need a new OME steering stabilizer. Which RTE springs did you order? The type of wheeling you plan to do will determine the wheels to use. Most people that play medium to hard always use 16" wheels for better tire designs, stronger side wall and less expensive tire along with the fact 16" tire will hold up much better off road and not tear out sidewalls as easily.
Old 02-05-2010 | 11:46 AM
dirk124's Avatar
3rd Gear
Its going to be strictly for looks my friend. im just getting the medium duty rr4 and rr3. so i do need a new steering stabilizer? i plan on getting some 16's in the future but for now im just going to stick to the 18's
Old 02-05-2010 | 12:47 PM
gowest's Avatar
It's worth the few extra bucks to get the stabilizer after a lift. Also, consider how you want it to ride to determine your spring type. Then, go 275 70 18 tires on your rims.
Old 02-05-2010 | 01:48 PM
salve7's Avatar
I've got a set of 16" rims I can hook you up with for cheap if you drive a D2 and are interested.
Old 02-05-2010 | 01:58 PM
gowest's Avatar
It can more expensive to get good 18" tires than it is to get 16" rims and really great tires. It can be cheaper as the big 18" tires are so expensive.
Old 02-05-2010 | 03:23 PM
bvamcknight's Avatar
How is it going, just wanted to say hi to everyone,
Old 02-05-2010 | 03:55 PM
okdiscoguy's Avatar
It has been mentioned, But I would like to stress new shocks again.....
and to bvamcnight - hi, I hope you are not a spammer...
Old 02-05-2010 | 04:57 PM
yesmar's Avatar
http://www.rovertym.com/suspensionkit.htm
ideally this a list of stuff you should get. weather you get it all from them or part the stuff together.
Quick Reply: 2" rte
