2000 D2 still dead
2000 D2 still dead
Sorry I haven't been on here in so long, I was so busy with work and so disgusted with the disco I just let it sit. Where I'm at is this, after replacing the crank sensor and cam sensor(used part for that one), if it is below about 50ish degrees it will fire right up, the colder out it is the longer it will run. As soon as some magic temperature is reached it will instantly quit and wont even think about starting until it is completely cold again. When it is dead it has weak or non existent spark. When I pulled the codes it only came up with P0563, and P1590 I couldn't see where those have anything to do with my issues. So do any of you guys have the foggiest idea where to go from here, I'm pretty disgusted with this thing at this point.
On the coil pack idea, I wondered about that also, but is there actually anything all the coils have in common? I could see one segment burning out but all of them, It didn't make logical sense to me. I am theorizing that I have a sensor going on the fritz or horror of horrors, a computer that is dying. With so little in the way of codes to go on this isn't going to be fun to track down.
When it does run it runs great up to the very instant it dies, I thought I had it fixed with the new crank sensor because I drove it about four miles without a hiccup and then left it idling and it died 10 minutes later.
on
Test the crank sensor with either a high end scanner or an OHM meter and see what sort of voltage it is putting out when the engine is turning over.
Also clear the codes and see if that high voltage code goes away, if it doesn't your alternator may be over charging and toast on of the ECUs.
