2000 dii won't start
Old Oct 5, 2012 | 04:50 PM
waweo's Avatar
4th Gear
Question 2000 dii won't start
I have a 2000 dii, drove home fuel light on, shut it off, 2 days later went to start would'nt, put in two gallons of gas still won't start. Here's the kicker, now the 4ways flash after about 30 secs. any clues/guess's already bald, and pulling on the beard hurts. txs
Old Oct 5, 2012 | 04:57 PM
lr2001silver's Avatar
Banned
May of sucked up some deposits off the bottom of the tank and clogged up the pump have you checked to see if your fuel pump is working or not? Have you checked to see if you have fuel up at the rail? Also when you 4ways are flashing after 30 seconds is that while your turning it iver ir 30 seconds after you close the door or what?
Old Oct 5, 2012 | 05:37 PM
jafir's Avatar
Flashing 4 ways makes me think you've tripped the inertia switch.
Old Oct 5, 2012 | 06:31 PM
waweo's Avatar
4th Gear
Get in, shut door, turn key to on, 4 ways flash, shut off /remove key. still flash remove fuse or disconnect battery to shut off.
Old Oct 5, 2012 | 07:01 PM
waweo's Avatar
4th Gear
Jafir you were correct, not sure how or why , pressed the little buton and it started, thank you and ir2001silver for your help.
Old Oct 5, 2012 | 08:04 PM
Banned
Anytime friend! Inertia was where i was going but i just wanted more info. Good job Jafir
Disco Alan
Nov 21, 2014 09:21 AM
toad2
Jan 17, 2014 09:19 PM
Mountain State Rover
Jun 29, 2013 02:06 PM
PK Disco 2
Apr 10, 2011 02:28 AM
focusontheworld
Dec 6, 2008 11:11 PM
