2000 DISCO II TYRE suggestion---
hi
For Disco II 2000 model, which tyre is the best one for regular commute and occational wet drive? . At present it has GOOD Year gave me around 38K miles. I need to change the front tyres.
Can I use Michelin in the front and GOOD YEAR in REAR?.
Any performance review? info will be great.
thanks
kris
thanks
kris
on
RE: 2000 DISCO II TYRE suggestion---
Not knowing if you have 16" or 18" wheels I can't get specific with sizes but consider the BridgeStone Dueller line. They make an H rated directional tire that is very quiet, has good traction, loves water and will give you alot of miles.
It is a little hard on a 4wheeler to run tires of 2 different sizes, even 2 new and 2 old, might consider 4 tire and rotate them so you get more even wear.
Mike
Mike
on
As long as it is the same wheel, new or used, this will not be a problem. If people will keep their air, ft/rear, the same, this will really cut down on the wear. My 265's gain 1/2 inch in height between 22#'s and 35#'s, so what ever you do run your tires the same.
Do you have any ideas what you are looking for yet?
Mike
Mike
