2000 Disco2 SparkPlug Electrical problem
Help, I changed all my O2 Sensors today and all was good after a test driveso I had ordered some Bosch Platinum 4 plugs and decided to replace them. Unfortunately I did not have new 8mm Magnacor wires to replace but decided looking at the old plugs I took out I would replace anyways. I did each spark plug individually as to not mix up wires. After changing them allI went to start up Truck knowing maybe it would run possible rough from previous threads (by not replacing wires).I couldn't belive it but it it just spun and spun not firing at alland than the outside Flashers come on, what the heck!!The hazard Switchdid not accidently get hit and I needed to Pull Flasher Relays to stop flashing.Next I put the OBD2 Scanner I have on it and it states Electrical malfunction(don't have codes #'s currently). I cleared codes with Sensor,pulled battery terminals off to clear also.
So I decided I would put an alternate plug like a Bosch +2. Same thing happens , turns over andover, flashers come on, not firing, and same code #1590 I think. Lastly I said forget itI'll put the old plugs(Champions) back in soI can get to work in the morning, still same issue. will not fire, and no it's not out of gas 1/2 a Tank. I'll Tell you I'm very frustrated at this point Isthe wires possiblygone bad from pulling them on and off., but wouldn't some of the cylinders fire.Is the Splitfire +2 or +4 Bosch Plugs not compatable with the Plug Wiresin Truck. Wires look about 2 to 3 yrs old, I've owned the truck 1 year. To change the Wires my hands are small but not that small what a bad spot to put a Distributor Cap!!
Sorry for the lengthy message, just trying to give best description of problem.
Truck is a 2000 Disco 2. 135,000 mi. Hope someone has had a similar issue!!Little help Mike?
on
RE: 2000 Disco2 SparkPlug Electrical problem
ORIGINAL: Darover
Bosch ????? oh , oh!!!! here comes the battle of the greats again!!!!!
Mike
on
1 Post
Whoa whoa whoa, calm the heck down! If you haven't had enough sleep, go back to bed! There's absolutely no reason for you to give me this attitude. I've never in the past commented on bosch plugs for I usually don't comment on things that I don't know about and always comment on personnal exprience.
I was making reference to you know who, who's always starting a war the second he hears the name bosch.
on
Here again, if you had read the originial complaint you would have seen this was not a spark plug issue.
What I stated was no attitude, very simply I don't believe people benefit from, he said she said storys they know nothing about.
At this point Eatman needs information that might get him past this problem.
Mike
Mike
Mike, Sorry I worked late and I'm also located in NH so it's EST here.I did what you said numerous times but no luck,I also cleared the codes after and tried it again but no luck. Here are the error codes I mentioned that werecoming up. P0560, P1536, P1668.
Thanks again Eric T
Thanks again Eric T
