2000 SD7 cruise control
Old Jul 23, 2007 | 08:08 PM
2000 Disco 2 SD7's Avatar
Default 2000 SD7 cruise control
My cruise control sputtered and died, and I checked for location of cruise box per Okdisco's 97 and found nothing that remotely looks like a cruise box in the LH front. For that matter, no obvious vacuum lines could be found either. Help! Someone stole my cruise box or it is hidden underneath something for the 2000 model year. So, where do I find a service manual that has plenty of photos that will help me find the not too obvious components?
Thanks,
Dave
Old Jul 23, 2007 | 09:50 PM
okdiscoguy's Avatar
Default RE: 2000 SD7 cruise control
look under your jack, underside of the metal plate it sits on.... should be able to follow the line down there...I'll try to get a pic later.
EDIT :OK, someone could have corrected me.....I have a D1, here is yours.....
Old Jul 24, 2007 | 09:40 AM
Does the power light on your cruise control come on? If so you most likely have some cracked vacuum lines that need to be replaced, make sure to check the line that goes to the switch located on the brake pedal arm.
Mike
Old Jul 24, 2007 | 02:03 PM
okdiscoguy: Thanks much for the photo, definitely worth a thousand words! Is there more than one publisher of a chassis service manual, and if so which is the best for me to buy?
Disco Mike: yes, the power does come on, so the vacuum lines are what I'll be tracking down and replacing. I think I read they are 7/32" somewhere in a thread, but will cut off an end for matching up at the parts store. Thanks for the help!
Old Jul 24, 2007 | 02:28 PM
okdiscoguy's Avatar
go to rover-renovations.com search for the Rave CD> They will send you one for free. Should have all you need...
cadetgrl24
Feb 15, 2012 09:07 AM
cadetgrl24
Feb 15, 2012 09:00 AM
cadetgrl24
Jan 31, 2012 12:49 PM
00discosd7
Dec 28, 2007 09:40 AM
00discosd7
Nov 25, 2007 11:52 AM
