2001 Disco - rear window stuck in down position
Hello:
My 2001 Disco's rear window is stuck in the down position. Fuse was checked and is fine. Neither switch (console or on door) is working to raise this window. No noise coming from window motor when either switch is pressed.
I read there is an ECU connected to the operation of the rear windows. Can someone tell me where it is located on this vehicle?
Any other ideas? Much appreciated!!!
I had a link to a site that showed how to repair a cracked window ECU. The solder cracks on the circuit board and then the window will not work.
Of course I cannot find the link now.
I believe that it is behind the glove box. Remove the ECU, find the crack and re-solder it.
ajs33
Feb 19, 2013 08:18 AM
