2001 Discovery 2 transmission fluid additive?
Going to change out the fluid on my disco tomorrow. I could swear I had read about a beneficial additive to toss in there while i was at it, but I'm not finding it again. Any tips on additives, if they prove beneficial I'd like to use one.
If not then less to buy at the store.
Thanks
Thanks
Well im all done with the fluid change. Only 4.75 ish quarts came out, pretty murky brown looking. . But the same amount went back in. Went through the gears. Went for a drive. Still held the same amount. Calling it good i suppose. Gonna change it out again in a few weeks to get more fresh fluid in.
Damn. Thanks for pointing that out from the rave. I screwed that part up in my procedure. Not just a typo. My rave download isnt working and i went off a sticky guide. I must have missed to keep er runnin..Crap
Back out to check and fill one more time i suppose.
Thanks
Also found a new rave download thats working well.
Thanks
So I did it per the rave exactly this time. Took about another quart. About 5.5 total.
Feel better about it now. Gonna try to do 2 more times over a few weeks to get more newer fluid it. No problems with the tranny. Hopefully none surface from changing fluids. My 2000 mercedes tranny took a dump after fluid change and was fine up untill it. And the damn stealership did that service
