2002 Chawton White - A Buildish Thread
Old Sep 5, 2013 | 12:52 PM
ZGPhoto's Avatar
Agreed, not hard, just time consuming and I cut myself on the metal a few times.
Thanks Andrew! I will do a post on the air compressor in a bit, I used the CKMA12 ARB air compressor.
Old Sep 5, 2013 | 01:08 PM
dusty1's Avatar
wow, I can't believe that arb is so heavy that you had to use those dam* cables to hold it up. what a pita
Old Sep 5, 2013 | 01:10 PM
dusty1's Avatar
seriously though, it looks great. I like the risers.
are you still planning a bumper swap?
Old Sep 5, 2013 | 01:12 PM
ZGPhoto's Avatar
Better than before I had them, used to have to wrap the winch cable around the roof rack!
Yes- I will be getting a new bumper.
Old May 15, 2017 | 04:01 PM
EasyDoesIt's Avatar
Great looking rig. I read on your Panhard Conversion thread that you were installing Bilstein 7100s on your 3" Terrafirma lift.
How did you like the Bilstein 7100s and which ones did you get (PN or size)?
Old May 15, 2017 | 04:16 PM
ZGPhoto's Avatar
Little change on direction with that. Not really a fan of Terrafirma any longer, I went with RTE springs. I then decided after buying the 7100s, that I'd like to try the Fox shocks instead. Some info here- 2002 Chawton White - A Buildish Thread - Page 7 - Expedition Portal
Old May 15, 2017 | 04:58 PM
OverRover's Avatar
I'm surprised it took you this long to realize that the Terrafirma Kool Aid is poisonous!
Old May 16, 2017 | 09:16 AM
ZGPhoto's Avatar
You can only replace so many shocks before it gets old. I've had good luck with a few other items they make.
Old May 16, 2017 | 01:29 PM
FloridaRover's Avatar
Cool build, great pics! - What camera are you shooting with?
Old May 16, 2017 | 02:53 PM
ZGPhoto's Avatar
Was a 5dmk2, now using a 5dmk3
