2003 disco engine knock
http://www.youtube.com/watch?v=jmw9m...ature=youtu.be
Hey guys, a disco im looking at purchasing is near immaculate except for this knocking coming from the engine, my guess is lifters. But im worried it may be rods. The only solace is that the sound wasnt present when the vehicle was first started, it only came when the engine warmed up. What do you guys think?
Well you said after it warms up You get a knock. When I drive my 2000 around to test drive it, it ran perfect. But on the long trip home I got a knock. .. Mine was more of a loud tick. I plugged an ultra gauge into the obd port under the drivers side of the dash, and found my temps were too high..the oil was getting too thin. I cooled the motor down, and ran rotella and the tick went away completely. ..
I'd say that is an awful tickknock. Be interesting to see what the oil pressure is on this engine. Low oil pressure could of course lead to lifter ticking/knocking. Your Bearings could be badly worn driving the low oil pressure.
Knowing these engines better than I'd like I would lean on it being a slipped liner.
You could try changing the oil with a Heavy Straight weight oil (50W) with the hopes that it is a lifter and this will keep it pumped up even at operating temps. A lifter/cam R&R is not a bad job.
See if you get the oil pressure check and let us know what your seeing at warm idle.
2003 LR Discovery Engine knock - YouTube
If it's not a STEAL, I would keep looking just to be safe.
You never know. I've seen some nasty valve trains on these engines. I would agree you need to keep looking for one that is solid (for now).
Thanks for the input guys. Yah ive still been shopping around, ive looked at, listened to, and driven 11 different discos now (starting to get a feel for them) and this one felt the best when driven and absolutel looked the best inside and out, just that one damn (potentially catastrophic) knocking sound. It only has 88k miles and is a 1 owner vehicle with pretty solid maintenence records. He's asking 4800 but im pretty sure i could drive away for 4500. And if i just need to replace the lifters and cam, id ****** it up tomorrow because it is head and shoulders above anythig else ive seen, but if it is a sleeve or a pushrod or any of the other numerous possibilities...id be screwed. Seems like the general concensus is keep looking? And thanksso much again guys for all your input, ive been so excited to get my hands on a disco and im reaaalllly trying to make sure i get the right one
