2003 DiscoII transmission swap question (front drive shaft blew apart)
Temp ranges on the 5 D2's I've owned have all varied. I had one 02 that ran 205-215F and never gave me any trouble. Then I had two 03's that ran 195-205F, and 04 that ran 195-210F, and my current 02 Kalahari with 224K on it (the highest mileage D2 I've ever owned) runs 175-193F. I use a ScanGauge II to monitor my Alternator voltage, engine temp, Air Intake temp, and RPM's.
Switching to a 180F thermostat does wonders, a new Hayden Fan Clutch will also help, but since you have an 03 you will have to replace the fan with one from a 99-02 as the 03/04 units are one piece which won't allow you to change just the fan clutch out.
I'd also suggest changing to normal green antifreeze vs the red/pink stuff.
I had the same idea when I last had the upper intake chamber pulled off. I wasn't in the mood to crack the cooling system open, or I would have pondered on the retrofit of a thermostat onto the block.
Glad to know I'm not the only thinking along this line. We should start our own thread. Sorry to threadjack OP.
