2003 HSE Disco will not stay running
2003 Discovery 2
4.6 V8 with 149,xxx miles I purchased it not running for $1K, so not looking for sympathy just a little guidance :). The truck currently has the 3 amigos + CEL warning lights. A review of the codes using a Innova 3130 scanner I receive P0300, P0302, P0305 and P0307. If I clear the codes, the CEL remains on. To clear the CEL I remove the battery and short the + pos and - neg battery leads together. Once this clears the CEL, I can start he truck. It runs seemingly fine.... for ~10 min then shuts off with the random misfire and various P030x codes. What I have done so far is this:
I have in my possession:
My question is, what scanner / code reader should I purchase as I am guessing the Innova is not reading some LR specific codes as the CEL remains on after a reset. I see recommendations for iCarsoft, Hawkeye and NT510. Is there a clear winner i.e. the best return for the investment? Any other or better recommendations to perform either before I replace the coils and wires or during replacement in order to get this truck running? Thanks, Troy |
If you want a basic scantool the LR iCarsoft is good. If you want a more advanced unit then the Nanocom, & Hawkeye are good choices. |
Mr. Best4x4,
Thank you for the recommendations. I expect the programming key-fob function will be something I need as I only have 1 key currently so the more advanced set will be what I am leaning towards. I will look into the Nanocom and compare it to the Hawkeye. Thanks. |
Since you have the parts for replacement, try to replace them first and see if it improves the condition. Seems like you have the right parts to make it right.
While you are doing the coil packs you will have access to the Fuel Injectors. You can pick up rebuilt on EBay for $60 or so. If they look in poor condition, it won’t hurt. |
Here is what the Innova "predictive fix" suggests, I will work up this list beyond what I already have from least expensive to most, given it could be any of them.:
Does it run and just die off? Or run and abruptly quit with no ability to start back up? my Idle Control Valve was throwing an error in the scantool, so I didn’t even look at it; I just bought a new one. When it arrived I went out to install it...and my existing ICV was simply unplugged. They do not have a locking clip (why?) and it had vibrated loose I guess. Plugged it back in, hit the key...ran like a new Cadillac without even touching the gas pedal. Doc |
your misfire codes indicate bad coil packs, it likely is running until it gets up to operating temperature and then the bad coil packs are failing on it. I would recommend replacing the coil packs and buy one of the Amazon Bluetooth Elm code readers and watch your oxygen sensor charts after she's warm
Originally Posted by ReconDoc83
(Post 673700)
Originally Posted by Extinct
(Post 673751)
