2003 se
on
It will fit, but it is different then your harness goes. The earlier t/case, 99 thur late 01 had a lock out solenoid, to prevent shifting while the tranny is in gear, located on the top of the t/case, the 03 and 04 solenoid is located in the console. There were also a number of changes on the 03 and 04 t/case, if you want to get a CDL, either find an 04 or buy the CDL nose assembly from a 99 thru 01 and rebuild yours.
seamonkey1
Tires
05-19-2011 07:45 PM
