2004 Disco 2 Engine Rebuild
Recently purchased a 2004 Discovery with 122k miles. It was running rough and exhaust smelled like coolant so I thought I would go ahead and replace the head gaskets. Unfortunately, it turns out #5 has a slipped sleeve and there is damage on the deck between 5 and 7 see below). So now I am looking at replacing the engine. This will be my first engine replacement. Below is my high level approach. I would welcome any suggestions or advice.
https://cimg3.ibsrv.net/gimg/landrov...3727092d25.jpg Damage with gasket pulled off https://cimg8.ibsrv.net/gimg/landrov...ef789705a1.jpg Up close and cleaned off a bi |
or maybe different type liners? Top hat and O ringed.....
Flanged or Top Hat Liners in Land Rover Engines - JE Robison Service - Bosch Car Service Specialists ? the blog and a new oil pump..... |
If the bare block hasn't been pressure tested, then pressure test it. If it passes, then:
Chem dip it to clean internal oil and coolant passages Deck the block (especially verify internal flatness) Install new cam bearings Install new cam (this is your one shot for internal power gains) Pin OEM cylinder liners (free) or install new top hat liners ($) Hone each cylinder Machine original crankshaft .020 and reinstall with new .020 main bearings Blueprint the non-oil piston rings on each cylinder to factory gap tolerances + use new ridged oil rings Install pistons/rods Install new .020 rod bearings (best practice to use new bolts on the caps here) Verify that crank turns (should require long screwdriver/pry tool) with effort, neither locked up nor spinning freely Oil soak overnight and depress each new lifter several times (only use new lifters with new cam, otherwise use original lifters w/original cam) Verify pushrods are all straight Verify rocker spring mechanism is straight Pressure test and chem dip heads Deck heads Verify straight valve stems Lap valves/seats and use carb cleaner spray through intake and exhaust ports of heads to verify that no valves leak any carb cleaner) Replace valve stem seals Port head exhaust openings and port exhaust header connections to heads to match the maximum size of your exhaust gaskets (free gas mileage+power here) Use ARP studs/nuts and all-metal Cometic headgaskets to reassemble heads onto block Uninstall, clean, and reinstall oil pickup tube, also use new o-ring on it Clean oil sump pan Install new timing chain and oil pump gear (plus new front cover if the old front cover is scored/gouged/damaged) Reinstall oil sump pan with new gasket |
Is that what happens when liners go ? Looks like a big chip is missing from the block |
Is that block new or remanufactured Bare Block. Block is Heated to 180 Degrees then Pressure Tested to Check the Cylinder Sleeves for Leakage. The Cylinders are Honed and the Block is Decked. |
For the life of me I just cannot grasp why people insist on spending 6-8 k on rebuilding motors or getting a Turner. I don't care if you have a fur-lined glove box on that truck, it's value on resale just does not justify it. Find a good used motor and slap it in. Bingo you are done for 500 bucks plus a days work.
What am I missing here? |
I think a welding shop could fill in that erosion with new aluminum and then have the block decked-that is my plan if I find that on mine.. sometimes cast aluminum that is full of pores and impurities does not weld well... Exhaust gases shuffling through there because of blown HG caused that erosion.Mine runs great-just can't keep coolant in it and has the usual noises....I'll have my fingers crossed when I pull the heads this spring...
Originally Posted by redwhitekat
(Post 680931)
Originally Posted by cfz2882
(Post 680937)
(Post 680933)
