2004 Disco SE... need a (used/refurb engine)
He would need the ECU from a 4.0.
He would loose, are you ready? 8 horse power, the DII 4.0 has a wopping 192 hp, the 4.0 in the DI has 188 the 4.6 has 200 then 3.9 is 182hp.
The transmission is longer for the '03-04 models. It has a bigger pump.
As long as he uses a Bosch engine he can use any Rover engine he wants.
If he gets a 4.6 from a P-38 he can use his ECU, if he gets a 4.0 then he will need that ECU.
A DI engine will not work in any way, the Bosch has twice as many sensors as the GEMS.
Even though they use the same block and heads they have different things attached to them.
