2004 disco towing capcity
OK. I posted on here back in the Spring about getting my 2004 Discovery wired for towing my pop-up camper. Luis and Land Rovers Unlimited in Spirng, Texas did an awesome job. I need to post pics of the wonderful, clean work he did. We pulled our 3300lb pop-up with no problem but now we are wanting to move up to a bigger trailer. Luis wired the disco with a brake controller so my question is what is really going to be the capacity for towing. I know the manual says something like 7000 lbs in low gear ratio, but can i tow like that on the highway? What are your thoughts. You can email me if you like. We are going to look on Tuesday and I want to have a good idea before going to the rv dealer. Thanks for the advice!
George
George
RE: 2004 disco towing capcity
Nite train, it seems you are correct, BUT I have no idea why. The US land rover manual says Low range gears at 7700lbs, and for the life of me I cannot understand why ??????
In my owners book, there is absolutley no ref High or Low gears, the 7700lbs is what it will tow. The GTW is 14000 lbs or 6380 KG's
If you go here and check both the manuals for the US spec vehicle and European vehicle, you will see what im talking about
http://www.ownerinfo.landrover.com/e...prod/index.jsp
Even writing this message it still baffles me why it would be different over there..............towing in Low range is a stupid idea!!!
Your vehicles are the same as over here so I cannot see an issue tbh. It must be one of your funny laws, unless anyone knows the reason behind the differnece.
