2004 Drive Shaft
2004 Drive Shaft
So I bought a drive shaft off of ebay that shows that it will fit all D2's. Is it a one size fits all drive shaft? Only reason I ask is that BA sells a driveshaft that is only for 03-04. Every other company list their shaft for d2 all years. Any advice would be great before I sling this thing on the Rover.
I have an 04 that I've bought two front driveshafts over the years (Great Basin Rovers & Tom Woods) and both of them were just standard size. I've seen the spacers that you can get for the 03 & 04 models and they aren't that thick.
Both of my driveshafts worked well and I think it's just a matter of the spline part of the shaft expanding a tad bit more. Might worry me if I were doing hardcore rock crawling or something that put a tremendous amount of torque on the drive shafts but for running the roads and some weekend off roading in Georgia I've never had a problem with mine. Just remember to regrease the new one when you change your oil. It's a pain to do but just suck it up and the new shaft will last you forever.
You might find the bolts at a store like Fastenal, but HD, Lowe's probably not. They are 3/8 UNF X 1.125 (approx. 30mm) and it's the odd length that gets you. Grade 5 or 8 will get it done.
You can get the bolts #509045P single from most LR Parts retailers(shop around) like > BOLT PROP SHAFT 3/8" UNF, RNC184, 509045P, LR045409 - Rovers North - Classic Land Rover Parts or as a set > Range Rover Discovery Defender Driveshaft Drive Shaft Bolt Nut
Also, I would highly recommend this tool as one to have. Makes life easier in so many ways, especially on your knuckles on cold mornings. Not cheap but not overly expensive either and after using it a few times I would have paid twice that for it.
https://www.lucky8llc.com/collection...shaft-nut-tool
