245 vs 265/75r16? Rub? Power? Flex?
Old 10-14-2009, 08:52 PM
oysterhead's Avatar
Default 245 vs 265/75r16? Rub? Power? Flex?
My goal is to have a truck that can handle difficult, rocky trails but still ride nicely on the commute. I'm planning on a 2" OME HD lift (or maybe the 781s).
I've been cracked-out searching the gazillion threads on tire size, but I'm still torn on 245/75 vs 265/75r16...and have some questions for those running these size tires.
1. On the 265/75, should I expect any rubbing at all? Will I have to trim the front bumper or rear mudflap? I'm talking on the trail, under flex. I'm fine with adjusting the steering stops, but I don't like the idea of gaining lots of flex with the OME, only to stuff the wheel well and have rubbing when I'm pushing it!
2. On the 265/75, do you actually notice the power loss? To a point that it affects your ability to climb/crawl in 4 lo? I'm okay with a loss in MPG, but think I might prefer a smaller tire over a weaker engine.
3. Does the 245/75 look silly with a 2" lift? Got pics?
Thanks in advance.
Old 10-14-2009, 09:06 PM
Long Haul's Avatar
I am running 245/75r16s under my D1 i think it has a great stance.I am running 2" rte springs.As soon as i figure out how to post a pic of it i will
Old 10-14-2009, 09:20 PM
Long Haul's Avatar
Old 10-14-2009, 09:47 PM
malmberg's Avatar
From what I have read on these forums the 245s are great for the D1 and the 265s for the D2 work out great.
Old 10-14-2009, 09:54 PM
oysterhead's Avatar
malmberg, do you rub on trails? did you do any trimming? when you threw on the 265s, did you notice a loss in power?
are you rubbing here?
Old 10-14-2009, 10:30 PM
malmberg's Avatar
I haven't trimmed anything.The only rubbing I have is with the wheels hitting the radium arms at a full turn. Offroading I haven't had them rub anything. I think that even after I get some disconnects they will stuff fine with no rubbing. As for the power, I did notice it wasn't as peppy as it used to be. When you throw it in low and are crawling around there is still plenty of power. Overall I am very happy with the 265s. I like the wider tire look over the 245s.
Old 10-15-2009, 07:46 AM
jycsalas's Avatar
i like the 245
Old 10-15-2009, 09:23 AM
Yes, you will see/feel the difference when running 265's. You will loose around 1.5 MPG in town, less on the road and your low end torque will drop a little.
As for flex, look at my pictures in the photo gallery and judge for yourself. I run 265 BFG MT's and swear by them.
Old 10-15-2009, 09:38 AM
oysterhead's Avatar
but you're running a 3" lift, right Mike?
Old 10-15-2009, 09:40 AM
Yes, but the 265's work well with a 2 to 2.5" lift.
Which set of coils are you planning on using, this will also make a difference?
Quick Reply: 245 vs 265/75r16? Rub? Power? Flex?
