3 amigo solution or time to part out
I really like my DII and would like to keep it but it has become a safety liability. The tires skid on wet and loose surfaces due to ABS not functioning properly while 3 amigos are on. Here is a description of the symptoms over the past 10,000 miles.
occasional 3 amigos for a while
consistent 3 amigos
pull code (electrical failure shuttle valve)
replace shuttle valve (purchased new valve from Atlantic British)
no amigos for a while (2000-3000 miles)
occasional 3 amigos
occasional turning into consistent 3 amigos
I have an autel code reader but it will not clear the code. The 3 amigos come on randomly but sometimes they coincide with outside events like hitting a bump in the road or driving in rain.
consistent 3 amigos
occasional 3 amigos
Did you replace the valve or the switch? The valve assembly is over $700.
Shuttle valve switch: http://www.roverparts.com/Parts/SWO500030.cfm![](http://www.roverparts.com/product/img/Icn/SWO500030.jpg)
Shuttle valve assembly: http://www.roverparts.com/Parts/SWO500040.cfm![](http://www.roverparts.com/product/img/Icn/SWO500040.jpg)
I love the LR3. Only complaint I have is that some of the interior seems a little cheap. I blame ford.
![Wink](https://landroverforums.com/forum/images/smilies/Uh2vXQr.png)
Read through this ABS shuttle valve code solution; brake fluid leaks that references replacing the valves and the seals. May not need the seals, but that can leak, but I did both. Note from this link of importance to you. "If intermittent through the modulator board, our kit (shuttle valve and seals) will not repair that aspect. The poor connection is generally a cracked solder-joint on the board in the solenoid block, and it must be located and repaired. Alternatively the whole block can be replaced [pricey] or circuit board bypassed. The next step referenced below is the bypass option and is the step you need to complete. Skip down to "Option B" in the link which is Step 37 to see wiring re-work that completes the job. You may also need the seals.
ABS Mod - LAND ROVER CLUB V.I.
Since I did the fix I have had no issues for a couple years now. I do now have my amigos back and having read the codes with an ABS Amigo, I have issues with a wheel sensor, but no electrical faults. So the valves, the seals and the bypass address all the issues that can occur, well maybe not all, but the ones I have seen discussed. My idea was to replace valves, seals, and do the bypass wiring all at the same time while I was doing the repair. After complete, I tested my old shuttle valves, and they were in fact still good, sending the signals as needed when I tested using a meter, so I kept my switches for a spare, but doubt I would put them back in, I would buy new.. This is basically a 60K mile recurring maintenance item per the FalconWorks pages as the seals are like other rubber type components and are in contact with brake fluid.
Replacing seals specifically is reviewed here:
http://www.landroverclubvi.com/abs-svs-seals.html The seals are rather pricey, but I am sure the price was determined not by their costs, but by their value to you the consumer versus the alternative price for new modulator.
Just like a D2, most things can be done with a code reader and simple tools. But like a D2, certain things might require a more specialized code reader, so that you aren't guessing what is wrong.
DiscoBenjamin
07-11-2011 06:29 PM
Landys4ever
08-10-2009 01:06 PM
