3 amigos, bad abs brake modulator
RE: 3 amigos, bad abs brake modulator
I cleaned the brakes with brake cleaner, then put sound dedener on the pads. The Sqeaking is gone now. When I start the vehical the ABS light comes on then goes off after I start driving. As soon as I hit the brakes all three lights come on (ABS,TC,HD). Does this still sound like the pads were causing this problem? The shop is convinced it is the modulator, but you have alot more experiance with land rovers.
Thank you,
Willie
Thank you,
Willie
ORIGINAL: fsix
Hi,
having the same problem, has anything come of this post?
Thanks,
Hi,
Thanks,
Send Willie a PM and see if he has found and corrected the problem. This is one of the reasons I am a strong believer in posting a fix once you find it.
If you have a problem and then fix it, PLEASE post the fix, even if it is months later.
