3 amigos (bad wheel sensor now what?)
Armlock
I just had my front sensor replaced last week by the used car dealer who sold me my 98 ( that was what we agreed on when I bought the rig). His mechanic got the part in around 3 in the afternoon and had it ready for me before 5pm. the ABS light is off (except when you first start the car) and my antilock doesn't lick in when it shouldn't anymore. So sounds like it shouldn't cost anywhere near what your dealer quoted.How do you find a good fair priced mechanic? that's another thread Good luck
Thanks for the help guys, I live in Bristol TN the closest dealer is about 2 hours away this is my first disco 02 84000 I have had it for about 2 months and i love it ,im a fair mechanic so anything i can do myself i will try, I know there are a thousand threads on the ABS stuff so i will do some searching , but could someone clarify if you replace the faulty sensor will the fault reset on its ownor do you still have to have the computer reset? Thanks in advance
As an alternative to the dealer you can try these Independant Rover mechanics, they have the specialized Rover TestBook diagnostic equipment to turn off your ABS light.Though it's still going to be a drive: http://www.rangerovers.net/service/south/ncarolina.html, http://www.rangerovers.net/service/south/tennessee.html
I would object to paying anything more than thier minimum 1hour rate for turning the light off. Probably only take a few minutes to do it but they gotta recoup thier investment in that very expensive test equipment.
Chances are it is not just a sensor, if you've got a D1 rebuilt your rear hubs, if you've got a D2 you'll need to pull the hubs to check for bearing play. The ABS design on these is horrendous, if the bearings wear at all the reluctor ring in the hub can shimmy, this causes spurious readings that freak out the computer.
A new D2 hub is $400, a new sensor about $130... so it really makes sense to check them. The one advantage of a new sensor is you get a full length cable now on them, but it makes it a bigger job to install since it's not just a plug anymore.
cammyr01
01-05-2015 02:42 AM
