The 3 amigos came calling this morning
Old Jun 27, 2009 | 11:48 AM
tastandish's Avatar
Default The 3 amigos came calling this morning
Ok, wouldnt you know, yesterday I asked what the 3 amigos were and today they showed up!! is that Murphy's law or what?! So what do I do now and how bad is it?
Old Jun 27, 2009 | 11:52 AM
JBEGIN's Avatar
you can either go to the Dealer and have them investigate or go to an indy LR Mechanic and have him read your ABS codes, providing that he has the software...
As to how bad it is, well that would depend on what the codes are, but it wont hurt your truck to run it with the 3 Amigos.
Old Jun 27, 2009 | 12:04 PM
tastandish's Avatar
Thanks, that was my biggest concern if I could drive it. Nothing feels any different and when I shut the engine off and restarted, the lights were gone. They came on when I was coming to a stop on a slope so who knows. I know the breaks need to be bled. Maybe that had something to do with it. I will get the codes pulled and see what they say
Old Jun 27, 2009 | 12:07 PM
Disco_Fever's Avatar
Over the past 8 months my "three amigos have come on 3 times and have automatically reset themselves upon re-starting the truck.
I know I'm about due for pads, and have begun to notice a little squeak. I'm going to order a set of pads from AB and put them on next weekend, as I begin the rest of the 60k service...
Old Jun 27, 2009 | 12:54 PM
Your lights keep coming on because you haven't set a fault yet. Are your brakes squeaking, if so, that will be what your problem is. Use lots of sound deadening spray and do a 3 pint of DOT 4 brake bleed and hopefully you'll be OK.
Old Jun 27, 2009 | 12:57 PM
So, have your brakes been squeaking, if you throw a panic stop from 30 MPH on loose surface, can you feel the ABS pulsate thru the brake pedal?
Old Jun 27, 2009 | 04:19 PM
tastandish's Avatar
No squeek at all...havent tried a panic stop yet but I will and see what happens. I do know the brakes need to be bled. They go pretty low and with a pump or two they come right up and hold. I also feel a little pull in the front end when I hit them...sounds like air in the lines right?
Old Jun 27, 2009 | 04:51 PM
Well, you have answered your on questions.
How mechanical are you, sounds like a front caliper may be failing and you need brakes. Expensive if you let someone do it.
Old Jun 27, 2009 | 05:20 PM
tastandish's Avatar
Thats pretty much what I thought but I wanted to see what you thought. Always good to get the full perspective before I go throw a wrench on it. Sounds like AB will become my new best friend with all the new parts I am going to be buying. Do you know if any of the good parts store chains carry Rover parts?...Napa maybe?
Old Jun 27, 2009 | 06:58 PM
AK Rover's Avatar
Nah, Murphy's law takes a back seat to Rover engineering. Some of the stuff Rover engineers came up with make Murphy look like an optimist.
