3 Amigo's just a question
Old 09-29-2021, 02:46 PM
Richard Gallant's Avatar
Received 1,177 Likes on 814 Posts
Default 3 Amigo's just a question
Had the random 3 amigos today on the way to work, when I had a chance I went out to pull them. But when I fired up the Disco to move it to a more work friendly spot of course they were gone.
Does anyone know if a pending code is saved ?
This happened once before about a year ago and they never came back, until now.
Old 09-29-2021, 05:52 PM
Harvlr's Avatar
I get the same on mine a couple of times a year, ever since I put in an ‘03 SLABS. It has only happened after hard acceleration after a stop. If I turn the key off for a few seconds the lights remain, but if I turn the key off for a couple of minutes the lights go away and stay away (for another half year or so). I think it’s a non issue myself.
Richard Gallant (09-29-2021)
Old 09-29-2021, 06:58 PM
Discorama's Avatar
I got the 3 amigos on an off-road tour. Used HDC a lot when the car was shaking heavily. I bled the brakes in the evening and there was some air in the fronts. After I came home I reset the codes and they never came back. Maybe you should do a brake bleeding to sort that out. It is a very simple job with a power bleed (short connect the ABS relay switch).
Old 09-29-2021, 07:36 PM
Best4x4's Avatar
Received 2,297 Likes on 1,688 Posts
If you get that happening before Option B you probably have bad insulation on the shuttle valve Switches or the internal connector is causing it. If you have performed Option B and it does it either you didn't cut the connector off which goes up inside the Wabco Unit (have found this a lot lately on several D2's), or the ground isn't good enough.
The Deputy (09-30-2021)
Old 09-29-2021, 08:22 PM
@Best4x4 No option B yet as I have had no problems, might be in my near future
Old 09-29-2021, 11:36 PM
Harvlr's Avatar
Mine has option B
Old 09-30-2021, 12:37 AM
The Deputy's Avatar
Received 1,275 Likes on 896 Posts
Codes should be stored, typically, ABS codes can not be cleared if active, or, they are stored and only cleared if inactive. Just checked the 04 yesterday afternoon (before leaving work), after ABS, TC and Hill Decent lights came on during the ride in.
Shuttle valve code. Hurray.
Richard Gallant (09-30-2021)
Old 09-30-2021, 12:30 PM
Thanks all as usual all is good, I will check for stored codes. An LR gremlin is sitting somewhere, trying to figure out what to do next to drive me nuts.
Old 10-01-2021, 01:44 PM
mln01's Avatar
Option B is not difficult or expensive to do, thankfully.
Richard Gallant (10-01-2021)
Old 10-02-2021, 10:13 AM
Fallstaff's Avatar
I’ll also champion option b. Well worth the effort.
Quick Reply: 3 Amigo's just a question
