31's on stock discoI?
RE: 31's on stock discoI?
31's might "fit" but not too well. also, i think that width is too wide for stock rim ideally and may rub just because it's tread corner reaches the big arms too soon even if it weren't 31".
so, the stock tire size in michelin xpc is realy great unless you add the old man emu springs/shocks as mentioned above. i did a simple medium duty which added about 2" allowing the tire size mentioned as well, 245/75-16 in a bfg AT and MT on another set of rims. they rub as well unless you back off the steering stops. your turning radius will now reduce as well but you'll have more clearance under the body as well as half the height of the tire size increase. that particular tire size isn't too wide either but is more appropriate for the D1.
no other mods are needed if only going 1-1/2" to 2" more on the springs but beyond that starts to affect other aspects of the linkages and gets you into all sorts of things to change to make it all work.
ORIGINAL: alex of minnesota
i need new tires. will my 96 disco fit 31's on the stock suspension, or do i need to keep them a little smaller? what about width? will 10.50" rub real bad on turns?
basically, whats the biggest i can fit on the stock suspension?
inside rear fender at the back about a inch.
The outside fender is unchanged.
fitch11
10-26-2007 10:04 AM
alex of minnesota
01-17-2007 12:51 AM
