3M Rubberized Headliner
I decided to do something about my saggy headliner in my Disco II last weekend. Being cheap and mildly resourceful, I took the old headliner out and stripped it of the cloth and foam backing (using a vacuum plus an attachment). Once it was stripped bare, I spray two coats of 3M Rubberized Undercoat over the entire headliner. Here is how it turned out:
It turned out well for the most part. My advice to anyone attempting this would be to let the first coat dry for at least 30-45 minutes before applying the second coat. I only waited 10 minutes and sprayed the second coat on too thick. In some places it beaded up and looking a little rough. Overall I like it. The smell gets to you if you leave the window closed. Complete drying and the smell going away takes about a week.
Cheers,
Pete
[IMG]local://upfiles/10333/2AD78EA05CE44C76B00094C26A12494C.jpg[/IMG]
Cheers,
Pete
RE: 3M Rubberized Headliner
ORIGINAL: WolfPack
Any reason you went with an Undercoat/suggested Herculiner? Wouldn't paint give you the same result?
Or would paint only stick if you really stripped the adhesive off?
I left the windows cracked slightly to aid airflow. It has almost completely dried after about 72 hours. Some thick spots are still a little sticky. The smell is mostly gone.
The headliner backboard is made of foam sandwiched with a thin fiberglass layer. It bends very easily so be careful handling it. I used silicon adhesive to reinstall a few plastic bits I broke being impatient.
Without the headliner it is very noisy inside. With the sprayed headliner it is very quiet. The black also absorbs more light, adding a little ambiance (so to speak).
Cheers,
Pete
Cheers,
Pete
The smell was what steered me away. I used the coating in a Ford truck I had once, and the asphalt smell never went away. Let us know how it dissapates over time.
I know what you mean about the color. When I got mine, it was bare. No backer, nothing. I drove it like that for over a year. I would get ice on the roof inside when driving in the winter... I finally got a backer and re-lined it myself. Really easy and less than $100. I had never done one before, and found there are a few tricks, but it looks good..... Black contrast is great...
