4.0 to 4.6l
Old 05-04-2009 | 10:37 AM
mrcrptguy's Avatar
Default 4.0 to 4.6l
just a quick question for someone that might know, can you bore a 4.0l and use 4.6l pistons? If so, can you use the 4.0l rods and crank with the 4.6l pistons??? THANKS!!!
Old 05-04-2009 | 11:30 AM
No need to bore it, the 4.6 is a 4.0 with a longer throw. (or is it shorter? I forget)
All you need to do is replace your 4.0 insides with those of a 4.6, so different crank, connecting rods, cam and ECU, without the 4.6 ECU you wont net anything other than money lost.
Old 05-04-2009 | 02:17 PM
Stroke it, add a 4.6 cam, maybe clean up the heads a little and you are set.
Old 05-08-2009 | 07:37 PM
NiteTrain's Avatar
is the rover 4.6L the same 4.6L ford uses in half it's vehicles or is that just a coincidence?
ok, nevermind I see now that they first used their 4.6L back in '96 when they were owned by BMW.
Old 05-08-2009 | 08:17 PM
The Rover 3.9, 4.0 and 4.6 are all the same exact engine, just different stroke.
I think but do not know for sure that the 4.2 is also the same engine.
Old 05-09-2009 | 11:09 PM
mordor110's Avatar
The RRC 4.2 looks almost identical to the early D1 3.9, so I'm pretty sure it's the same.
Old 05-09-2009 | 11:11 PM
mordor110's Avatar
Can you do the same with the 3.9L with a mechanical distributor? Do you really need the ECU? Mines a 5spd so don't think I'll be able to find a 4.6ECU that will work.
Old 05-10-2009 | 10:41 AM
On a 3.9, consider have the heads enlarged, a cam, headers, possibly larger injectors and you'll make even more power.
Old 05-10-2009 | 10:04 PM
mordor110's Avatar
Yeah I'd seen that the 4.6 RR P38 comes with factory headers? I was wondering if I could make those fit on to my old D1? Guess I'll have to keep an eye out for a cheap 4.6 P38 parts vehicle so I can experiment.
P38 headers:
http://cgi.ebay.com/ebaymotors/ws/eB...m=150334266698
