4x4 Hack: Using Your Emergency Brake As a Diff Lock
Old Jul 22, 2017 | 12:53 AM
No Doubt's Avatar
Default 4x4 Hack: Using Your Emergency Brake As a Diff Lock
Sometimes you can get stuck with a wheel spinning uselessly. Apply a tiny bit of emergency brake to allow power to go to a wheel that isn't spinning uselessly.
See:
www.youtube.com/watch?v=v1Dbkvgiozs
Old Jul 22, 2017 | 04:10 AM
OffroadFrance's Avatar
Hey, but it's a 'girlies' truck not a real one
Old Jul 22, 2017 | 03:55 PM
mdyates1985's Avatar
THIS IS SO TRUE! My D2 got stuck on a sand crest deep. I didn't have CDL at the time but wow the hand brake thing worked me out of it!
Old Jul 22, 2017 | 04:10 PM
No Doubt's Avatar
Sweet. Also, another 4x4 hack for really loose sand is to pull out your floor mats, dig under the stuck wheels, and lay a short track out with them. Much more traction driving over your floor mats than over loose, dry sand!
Old Jul 22, 2017 | 04:48 PM
Friday Night Disco's Avatar
Crap and I just spent all that money on a CDL....
Curious, as I was having a debate, can you use this trick if your front drive shaft goes out and you don't have CDL to get you home???
Old Jul 22, 2017 | 04:54 PM
KingKoopa's Avatar
Ill give you this information and let you do the math lol. The E-brake is a drum brake fitted to the rear output shaft of the transfer case.
Old Jul 22, 2017 | 05:13 PM
doing the math...This would cause both rear wheels to get power instead of the transfer case sending all the power to the front drive shaft. I need someone to check my math on that
Old Jul 22, 2017 | 05:24 PM
Red5's Avatar
Nah, that would send ALL of the power to the now missing front prop shaft. But without a CDL, if both rear wheels are on the ground, this is going to happen regardless of the P brake.
Old Jul 22, 2017 | 05:58 PM
No Doubt's Avatar
No.
Old Jul 22, 2017 | 07:26 PM
mollusc's Avatar
If your front shaft goes out, your transmission is probably going with it and you're not going anywhere...
