6 miles to the gallon blues
yep, one of the plugs came loose. The engine idles a whole lot better, ill see how my mileage does when i drive down to wilmington tomorrow.
on a side note, while i was out there replacing the plugs, i had several people come up and ask me what i was doing, when i showed them the +4 plugs i was replacing, they all told me how they had horrible experiences with them, including drop in gas mileage... so i'm pretty confident that my gas mileage should go back up.
i guess you were right spike about some engines not liking the +4s. At least i have the magnecor wires in there.
Spark plugs are a hit and mis thing I have found.
Some engines just like cheap plugs.
I use Iridium plugs in my truck and she like them alot.
They require less power than normal spark plugs but deliver a bigger spark.
So, so depending on how you feel and your budget you might want to consider those, or not, its all up to you.
I used Autolite Iridiums this time, Denso last time.
so i had the faulty o2 sensor replaced, it was the first one on the driver side, and on the way home i get the CEL light codes are:
p1158
p1316
I don't know what p1316 is, but isn't the p1158 o2 related? i really hope not, this is starting to get aggravating.
Is it possible my engine doesn't like the magnecor wires as well? It didn't like the +4 plugs, so maybe i'm better off with the cheaper ones. I never had any problems whatsoever with the other wires until i put in the +4s....
p1158
p1316
P1138 H O2 FAILED TO SWITCH TO LEAN, BANK B
P1316 MISFIRE CAUSED EXCESSIVE EMMISSION
Bank "b" is the passenger side........you may (should) replace that one also as the ecu may have a hard time computing why the difference between the 2 sides .......the difference between a new sensor on one side and an older one on the other.
So i switched out the magnecor wires for advance auto wires, erased the codes, and drove a buddy to goldsboro (120 mile round trip) The CEL came back on, this time just a p1158 and a p1158 pending code came back on. So my disco didn't like the +4s or magnecor wires,lol. I have no use for the magnecor wires, so if somebody wants them i'll mail em to you. I doubt they're faulty, so one of y'all can have at em. they're only a couple months old.
