96 Disco 130K miles runs rough at 30 50 and 70 mph
#41
Put the new wires in last night and no difference. Does anyone else have any suggestions?
I'm on my second fill up w/ premium fuel and a cleaner. New plugs and wires. New oil and filter. Ran seafoam through the vacuum lines.
It's got the same symptoms it has the whole time. It runs fine until it hits a certain point then it really cuts out and starts missing and sputtering. After I let off the gas, and put it back on it goes away and pulls through fine.
#42
#43
#44
This morning I changed the fuel filter and air filter. The fuel filter poured out muddy looking fuel from the intake side. It had lots of small black particles. The outlet side of the filter was putting clean looking gas through.
I thought it was running better but once I got up to speed it still was acting up. Hopefully the coolant sensor will fix the issue. I probably won't receive it in the mail until Monday so I guess we'll see then.
#46
So time for an update. I put the new coolant sensor on Monday evening. When I did this, I also changed out those leaking exhaust gaskets. Unfortunately broke off two studs in the passenger side down pipe flange. So it took me a couple days to get that fixed and got it back together last night.
It runs just as bad...possibly worse. It never gave me any trouble at idle until now. It still does the same thing at different speeds when under load - just cuts out then back in. But now it idles rough at times and sometimes stalls. I also see my speedo bouncing like crazy sometimes at an idle.
I've done some digging around and I'm wondering if the issue could be a bad VSS? Any thoughts from you guys??
#49
