96 disco duel exhaust
Yes, for the info going to the ecm it will make the cel come on.
You need to check what is needed for where you live.
I played with the exhaust and found that the cats don't slow
much down, flow or sound.
I put a Magnaflow muffler and a high flow glass pack.
(in place of the back small muffler)
The sound was nice at idle anything more and it was
a honda with a V8. Not good at all.
The other thing that I found was I did have more power
but at a higher rpm.
I could not take the noise I had the OEM pipe from the
muffler back with the OEM little muffler put on.
I had more TQ and power at a lower RPM and a good sound.
The TQ that I had unknowingly lost was back, the Hp gain was about the
same, this was all done by feel so it was noticeable.
the smaller muffler you replaced was probably a resonaor. That is critical to your exaust tone. without anything it'll drone inside the vehicle. Your best bet is to leave the resonator but put a more aggressive muffler on it. OR move the resonator forward (if it'll fit) and put a performance muffler where it was. You can also buy different resonators and what not.
If you really want true dual exhaust, (and i havne't been under mine but i've done quite a few dual exhausts) your best bet is to put a Y pipe after the last 02 sensor (normally in the CAT) and run dual 2.25 or 2" pipes to a pair of magnaflow or similar mufflers. You can probably get away from running a resonator if you run 2 good mufflers.
Normally this runs between 6-800 bucks for a custom job.
Street Wolf
06-24-2011 01:59 AM
fortworthcoe
06-02-2008 05:47 PM
