99 DII Bank 5 misfire
My 99 DII keeps giving me a SES code stating a misfire at bank 5. Have installed the 8mm magnecors as well as new plugs( Bosch +4s). The connections have been doublechecked, and the coil tested okay according to my mechanic. Any ideas? Spring has also brought the leaky sunroof.
The truck has 91k on it.The 305 code was the first, and only code that popped up just two days after I purchased the vehicle. This led to the mechanic discovering the head gasket. Both gaskets were replaced. as well as many hoses, and the water pump. I know the heads were pressure tested, however, I'm not sure cylinder compression was tested. The wires and plugs were replaced after the head work was done, and still the code appears after being cleared. I've alwaays used 93 octane gas.
-DN
-DN
Remove #1 spark plug.
Install compression tester.
Crank engine over for 5 seconds or so.
Write down reading.
Repeat on all 8 cylinders.
Compare readings, should not be more than + or -10 psi difference between cylinders.
I do not know what the correct PSI should be. (125 ?)
I do not know how to do a leak down test.
Now you do not want the engine to start so remove the fuse to the fuel pump before you start the compression test.
The compression tester screws in like a spark plug.
