99 Disco II Trans Temp Light
I have a 99 Disco II with 107k on it. Recently the trans Light has been coming on - Just me in the vehicle, so I'm not pulling a load or anything heavy - it comes on after about 15-20 minutes on the highway.....if I let it sit it'sll go off....any idea whta is causing the transmission to heat up?
ARRRRRRRGH - it came back on again - I guess I need to try changing the temp sensor - does anyone know the part number? Also Just as a side note the light comes on after driving about 8-10 miles or so and if I let it sit for 5 minutes it will go off and come on again after driving a bit (so it isn't in a constant on mode - not sure if that points to something different then the sensor)
One other symptom to consider is that since we changed the trany fluid - it takes significantly more time for the light to come on.....ie the light came on withing 2 miles now it takes about 10 miles - it seems like something is causing it to heat up - also there are no OBD II Codes thrown....any ideas?
