AB Extended Stainless Steel Brake Lines installed!
Well I needed to rotate my tires this oil change and decided to install the AB Stainless steel lines at the same time. The AB SS lines seem nice quality. I got them for $99 on sale which is about $50 less than the Goodridge SS lines. I called to find out where AB gets them. They said they make them in-house with some other parts in Australia.
http://www.roverparts.com/Parts/ABP218L.cfm
http://img.auctiva.com/imgdata/1/3/2...02592500_o.jpg 2nd check to see that you can loosen the bleed screw. If it turns counter clockwise continue the install if not go figure that out. Otherwise you cant bleed your brakes after the new SS line is installed! http://img.auctiva.com/imgdata/1/3/2...02593219_o.jpg Add some Teflon plumbers tape if you want for brake bleeding later. And your bleeder screw is loose now with a wrench on it. This may prevent air from seeping in the threads while bleeding. http://img.auctiva.com/imgdata/1/3/2...02593272_o.jpg This is a rear line(The way to tell is there is not an alumium mid-line holder as on the fronts) http://img.auctiva.com/imgdata/1/3/2...02592609_o.jpg Gently disconnect the ABS line from its yellow clips. Also remove yellow clips from old brake line. http://img.auctiva.com/imgdata/1/3/2...02592669_o.jpg Now put a 15mm socket on the back of the caliper brake line bolt. Gently loosen it. Good, now tighten it back and start on the top. http://img.auctiva.com/imgdata/1/3/2...02592838_o.jpg Clamp off the old brake line with ViseGrips or a clamp. This will keep a lot of fluid from seeping out while you loosen the top & Bottom. http://img.auctiva.com/imgdata/1/3/2...02592949_o.jpg Now use a 11mm open ended wrench to turn toward the front of you car to loosen the top brake line. You may need to oppose the line from under the holder so it will not twist the hard line. Remove spring clamp holder once bold it loose. Brake line should drop through hole. This is the hard part! Now remove the line from the back of the brake caliper. Make sure oil pan is positioned. http://img.auctiva.com/imgdata/1/3/2...02593022_o.jpg If you prefer add back the black plastic coil protector to the new lines. Also add back the yellow plastic ABS line holders. http://img.auctiva.com/imgdata/1/3/2...02592877_o.jpg Ready to install rear line http://img.auctiva.com/imgdata/1/3/2...02592914_o.jpg Now connect up the new line to the top hard brake pipe and attach spring clamp. You may need to bend spring clip more to make it hold tight. I discarded the C-clips included with the lines. The original spring clips hold the line better. http://img.auctiva.com/imgdata/1/3/2...02593169_o.jpg Now install the low part of the new line to the brake caliper. Sorry for the blurry picture. Its a different size bolt. Use a new copper crush washer in the inner & outer of new bolt. http://img.auctiva.com/imgdata/1/3/2...02593100_o.jpg Now repeat for all other wheels. Follow Flush brake fluid instructions from the forum. I used a clear hose to see bubbles. It was remarkable easy to bleed the brakes. I used over 2 quarts of Valvoline synthetic DOT4 brake fluid as seen in the Flush brake fluid for a full flush. All fluid looked new coming from the calipers. Also I put a 2x4 of wood behind the brake pedel. I had friends mess up their master cylinder by pumping all the way to the floor while bleeding brakes. I dont know if this is true for the Rover but it couldnt hurt. Good luck! I also rinsed down wheel well areas with Simple Green then shot it off with the power washer. Brake fluid is very corrosive. I didn't want it eating parts away after my install. Also get a full box of Nitril gloves & double them up. You don't want DOT4 on your hands. Eye protection is also advisable. Flush brake fluid The SS lines feel solid. The pedel response is firm and i can feel a difference in hard stops and normal driving. |
Very nice boss. Should of removed the calipers while you had the chance and painted them suckers candy red. For performance of course....:D
________ CUMSHOT HOMEMADE |
The one thing I didn't see you mention was doing a complete 3 pint brake flush to get rid of the old fluid and give you a firmer pedal.
Teflon tape should really only be used on tapered pipe threads, it's not meant for parallel threads and can come off inside (though not too likely on a bleeder screw).
Opening a bleeder and depressing the brake pedal all the way then blocking it down will lessen fluid loss and air ingress while changing hydraulic components. |
Nice write up, thank you.
Spike your welcome to change anything & make it a sticky if you want. I would be proud
Excellent write up, thanks!
Nice, thanks Boss! I plan on doing this when I install performance rotors & pads in a couple months.
+1 vote on the sticky. I'd like to see more stickies, AAMOF. What I've been doing as a new Roverite is bookmarking useful posts like these, but it'd be nice to see a repository of useful how-tos for newbies. I know there are several personal websites out there for this sort of thing, but there doesn't seem to be community contribution. |
+2 on the sticky. If it was not for the great brake bleed sticky, I would have taken my Rover to Midas to have the brakes bled. Turns out, bleeding the brakes on the Discovery is super easy even without a helper. That said your brake system has to be in good working condition in the first place. This is a cool $100 mod that is a doable Saturday job.
On my to do list!
