about to start head gasket job on 99 discovery II
I bought this discovery about a year ago it ran well and supposedly had just had the head gaskets replaced and the bolts replaced with studs.
About a month after I had it I noticed it was using oil and a bit of coolent .
It now uses quite a bit of oil esp at high rpm say above 3k
And you can smell the antifreeze burning. So headgaskets and timing chain I guess seeing it has 160k miles. Sad as otherwise is a solid truck and still runs great. So the real question is can I reuse the studs or do I need to replace them?
Also any brand gaskets recommended? I have already found a landrover frendly shop to have the heads checked. Any other advice?
So, I'm guessing you really check out the engine. Burnt antifreeze smell can come from the throttle body heater leaking dripping on the valve cover and then onto the Catalytic converter. Trust me when I bought my latest Discovery, it was leaking a Gallon a week, easily. And the oil can leaking from a number of spots including the time chain cover, valve covers, real seal, oil filter and heads and I'm sure I'm missing a spot or two.
So I'm all into doing work when it should be done. But your post says the heads were done recently and the car runs well. Now if your positive it's the heads do them. But if your guessing here, take it to a shop explain your concern and spend a 100 bucks to make sure.
Have them pressure test the coolant or check your oil for coolant. Even have them look for the oil leak.
I am not criticizing here I just want to make sure your spending the cash in the right places.
Pull the plugs to see if any are fouled. They should be a tan color for a correct running engine.
Make sure your PCV system is clean, too. Might be source of oil consumption, although it usually causes more issues with seal leaks. If you are burning a lot of oil and coolant you should be having issues with your O2 sensors. But incorrectly installed head gaskets are a definite possibility. I had a P38 that my brother-in-law had before me that ended up having the head gaskets done twice. He bought it used with an extended warranty so he had it done at a dealership and they screwed it up. It had to go to another dealership to have them done again within 8,000 miles.
I would say that a cooling system pressure check and a compression test are in order regardless. If you are willing to take on a head gasket replacement, you can easily perform those tests with loaner tools from the parts store.
Also, I noticed you said no leaks. Are you sure it's a Rover? If so, is it empty?
on
I would pressure test the block. I just had the same problem and now have to pull the engine and sleeve it. really look hard at your gasket when you take it off to make darn sure thats the problem. Just trying to save you the time that I didnt get to.
1999 Disco 2 coolant burner 205000km
2003 Disco broken cam crank ( parts )
1999 Disco SE7 300000km ( parts )
