ABS codes read what do they ALL mean??
I used an autologic independent machine with a land rover software version of 2.0.763
I just read soooooo many faults. The first six were fault present. The rest were FAULT LOGGED. 1)Shuttle valve switch electrical fail. 2) and 3) Rear left and rear right height sensor out of range. 4) and 5)Rear left and rear right corner valve power amplifier open circuit. 6) Exhaust valve power amplifier open circuit. 7)Rear left sensor output too low 8)Rear left sensor output intermittent 9)Shuttle valve switch electrical failure 10) and 11) Rear left and right height sensors out of range 12) and 13)Rear left and right corner valve duty cycle exceeded 14) and 15) Rear left and right corner valve power amplifier open circuit 16)Exhaust valve power amplifier open circuit 17)Unknown fault code 0000 also SRS code open circuit fault in LH pretensioner circuit. Any Ideas? |
As for the SRS, unplug the harness that goes to the seatbelt pretensioner and clean the contacts and then plug it back in.
As for the others how long has the "3 amigos" been on? Were they one when you bought the truck? If so reset them and wait and see what comes back. |
They have been on since i bought it.
I have reset the codes and those are the ones that came back. Its so many an mentions electric issues enough time that I am thinking it might be the abs module |
OHHH damn. I might have to go to a dealership then
It kinda sounds like the shuttle valve.
There is a rebuild kit that you can buy, or you can buy a used one. If you go the rebuild route make sure that you buy the GOOD one and not the cheap one because the cheap one wont work. www.atlanticbritish.com www.roverlandparts.com www.autosportsunlimited.com DiscoMike knows more about the ABS codes on a DII than I do. |
disco mike can you help?
These abs codes are confusing to me
Before you jump off a bridge, go clear the codes drive it for a few days and when the 3 Amigo's come back, get the codes read. Now by doing this, you will get rid off all the old crap and show what is currently happening. Then get back to us.
those are the reading that returned after i did that already.
