ABS codes read what do they ALL mean??
Old May 28, 2009 | 08:03 PM
aublec22's Avatar
Default ABS codes read what do they ALL mean??
I used an autologic independent machine with a land rover software version of 2.0.763
I just read soooooo many faults. The first six were fault present. The rest were FAULT LOGGED.
1)Shuttle valve switch electrical fail.
2) and 3) Rear left and rear right height sensor out of range.
4) and 5)Rear left and rear right corner valve power amplifier open circuit.
6) Exhaust valve power amplifier open circuit.
7)Rear left sensor output too low
8)Rear left sensor output intermittent
9)Shuttle valve switch electrical failure
10) and 11) Rear left and right height sensors out of range
12) and 13)Rear left and right corner valve duty cycle exceeded
14) and 15) Rear left and right corner valve power amplifier open circuit
16)Exhaust valve power amplifier open circuit
17)Unknown fault code 0000
also SRS code open circuit fault in LH pretensioner circuit.
Any Ideas?
Old May 28, 2009 | 08:15 PM
As for the SRS, unplug the harness that goes to the seatbelt pretensioner and clean the contacts and then plug it back in.
As for the others how long has the "3 amigos" been on?
Were they one when you bought the truck?
If so reset them and wait and see what comes back.
Old May 28, 2009 | 09:46 PM
aublec22's Avatar
They have been on since i bought it.
I have reset the codes and those are the ones that came back. Its so many an mentions electric issues enough time that I am thinking it might be the abs module
Old May 31, 2009 | 09:44 AM
aublec22's Avatar
OHHH damn. I might have to go to a dealership then
Old May 31, 2009 | 11:45 AM
It kinda sounds like the shuttle valve.
There is a rebuild kit that you can buy, or you can buy a used one.
If you go the rebuild route make sure that you buy the GOOD one and not the cheap one because the cheap one wont work.
www.atlanticbritish.com
www.roverlandparts.com
www.autosportsunlimited.com
DiscoMike knows more about the ABS codes on a DII than I do.
Old Jun 3, 2009 | 09:55 PM
aublec22's Avatar
Default disco mike can you help?
These abs codes are confusing to me
Old Jun 4, 2009 | 09:02 AM
Before you jump off a bridge, go clear the codes drive it for a few days and when the 3 Amigo's come back, get the codes read. Now by doing this, you will get rid off all the old crap and show what is currently happening. Then get back to us.
Old Jun 4, 2009 | 11:05 AM
aublec22's Avatar
those are the reading that returned after i did that already.
bonedoc
Mar 25, 2017 12:54 PM
kevlor80
Mar 2, 2017 10:37 PM
joeschuer
Mar 7, 2012 07:58 PM
traffictech870
Feb 21, 2005 02:30 AM
