ABS Modulator failure causing premature rear wear?
Looks like the infamous ABS modulator issues have not been worked out yet- have an '03 Disco with only 27k miles that had to have the modulator replaced (ABS, TC, and Descent lights came on)- luckily under warranty.
Could the modulator issue have contributed to the rear brakes wearing out completely while the fronts still had 80% thickness remaining? It seemed a little odd that the rears wore out quicker than the fronts... any thoughts? TIA |
RE: ABS Modulator failure causing premature rear wear?
I understand your concern. But the Modulator fault will not cause your condition. The rear pads just wear faster than the front. Nature of the beast.
