ABS Modulator failure causing premature rear wear?
Old Jun 19, 2005 | 03:19 PM
rebooTT's Avatar
4th Gear
Default ABS Modulator failure causing premature rear wear?
Looks like the infamous ABS modulator issues have not been worked out yet- have an '03 Disco with only 27k miles that had to have the modulator replaced (ABS, TC, and Descent lights came on)- luckily under warranty.
Could the modulator issue have contributed to the rear brakes wearing out completely while the fronts still had 80% thickness remaining? It seemed a little odd that the rears wore out quicker than the fronts... any thoughts? TIA
Old Jun 20, 2005 | 01:09 AM
Bait's Avatar
Default RE: ABS Modulator failure causing premature rear wear?
I understand your concern. But the Modulator fault will not cause your condition. The rear pads just wear faster than the front. Nature of the beast.
Wayne
Oct 2, 2020 12:10 PM
FlyingZebra34
Nov 19, 2013 03:07 PM
EstorilM
Aug 25, 2012 11:31 AM
lipadj46
May 24, 2009 09:04 AM
BlackDoubleR
Oct 11, 2007 09:05 PM
