ACE
Old Jan 14, 2008 | 11:28 AM
brooksa's Avatar
Default ACE
How do you tell if a DII has ACE? 2004 SE7
Old Jan 14, 2008 | 11:31 AM
spoon's Avatar
Default RE: ACE
Look underneath the truck real quick. If you see hydraulic rams in the place of anti-roll bars, you've got ACE.
Old Jan 14, 2008 | 11:41 AM
spoon's Avatar
Default RE: ACE
Actually, I guess the AR bars are there in fact, but here's a pic that might help you out. Also, look in one of the fuse panels. There should be a fuse for the ACE sensors, right?
Old Jan 14, 2008 | 12:17 PM
R_Lefebvre's Avatar
Default RE: ACE
Is ACE just "something else to go wrong"? Is it more reliable than the brake system? Is it a hinderance off-road?
Old Jan 14, 2008 | 01:25 PM
spoon's Avatar
Default RE: ACE
A hinderance off-road it would seem like to me... but it all depends on what kind of offroading you do. If you go rock crawling, you would probably benefit with the removal of the anti-roll bars and ACE system. Also, the ACE has nothing to do with the braking system. It's just a system that, by alternately stiffening the appropriate sway bars, greatly reduces body roll during hard cornering.
Old Jan 14, 2008 | 04:24 PM
humroot's Avatar
Default RE: ACE
Look at the power steering tank. If it's divided in half and the second cap has a pic of a car with 2 arrows, you have ACE. ACE (Active Corner Enhancement) will let you take on and off ramps at high speeds; it keeps the truck level during turns.
Tin_Man
Apr 12, 2014 11:12 AM
thehrdway
Apr 26, 2011 01:41 PM
tbuckt007
Apr 13, 2010 11:46 AM
alrd
Nov 17, 2006 11:25 AM
Charlie L
Mar 13, 2005 10:14 PM
