ace clunking
Old Mar 9, 2009 | 07:18 PM
05gixxer's Avatar
Unhappy ace clunking
Hello Having ace problems very loose feeling and clunking if I pull the fuse from under the hood clunking goes away replaced fluid in the resovoir four times replaced the filter in the valve block but still no improvement. When it is cold out 35 degrees and below ace will work for about an hour of driving before the clunking comes back. I noticed on another thread that replacement of the ace ecu resolved his problem I would try this but because mine works when its cold I dont think it could be the ecu.
Old Mar 9, 2009 | 08:44 PM
Contact UrbanPanzer, he knows alot about the ACE system.
You can find him in the member directory.
Old Mar 9, 2009 | 09:14 PM
okdiscoguy's Avatar
yeah, if you have flushed the system and checked your bushings, contact UP. Need to get someone that has it..
Old Mar 9, 2009 | 09:46 PM
tornado_735's Avatar
I was kind of annoyed when I found out I didn't have it, but should I be? One less thing to go wrong I guess...
Old Mar 10, 2009 | 08:47 AM
okdiscoguy's Avatar
Yeah, I stopped and drove an 01 at a car lot the other day because it had ACE. I noticed a difference on hard corners in town. It was sturdy. I popped the hood after the test drive to check the fluids and everything was black. Then I noticed the litle stream of coolant from the drivers side rear of the head.
I was looking for a friend whose truck had blown up. I asked the dealer if they knew all of the stuff wrong with it.....no idea. I ran down the list, and immediately he realised he paid too much for it. He was asking $7K and it had 110K miles...no thanks
Old Mar 10, 2009 | 10:11 AM
If I remember right, there may be a TSB out for that problem, might want to call your dealer and ask them to run your vinn for recalls and TSB issues that may be related to the Ace.
By the way, I also have Ace e-mail me your tele number, I may be able to walk you thru a couple things to check.
Old Mar 10, 2009 | 06:31 PM
PalmettoDisco's Avatar
I love my ACE.
One question, are you losing any fluid and having to refill to replace? Or did you replace it several times to have "fresh" fluid?
There is a known, likely culprit if it's losing fluid.
Old Mar 11, 2009 | 10:33 AM
If you are going to post a question, at lewast stick around to hear our replys!!!!!!!!!!!!!!!!
Have you had the system scanned for faults??????
Old Mar 11, 2009 | 04:53 PM
05gixxer's Avatar
Sorry for not checking in had to replace hard drive in pc yesterday took longer than it should have. Yes it does leak a small amount less than half a quart a month. I am trying to avoid land rover dealership at all cost does auto zone scanners have the capabilty to retrieve ace codes
Old Mar 11, 2009 | 05:43 PM
You forgot to mention the leak before, where is it leaking? When it comes to ACE, no leak is acceptable based on their pressure. If you want help with this you need to get a lot more specific.
